Brief Description: Installed top fuselage splice plate bolts & screws
Installed the top 8 fuselage splice bolts & screws. Riveted the bottom of the upper tie box in place. The plans call out AN7A bolts for the top plates and 2 washers each. I used AN6A bolts and one washer each because the 7A'a and 2 washers were not enough and I didn't want to try 3 washers on each bolt. AN6A bolts with one washer are the correct length.
