Brief Description: Turned fuselageand to install rudder cable pulleys
Finished installing the rudder cable pulleys with correct hardware. The plans call out non drilled AN3 hardware with typical nyloc nuts. If you use this hardware you cannot properly tighten the nuts without binding the pulleys. If you loosen the nuts then you run into the risk of the bolt turning and nut further loosening in use. The proper hardware for this should be drilled bolts and castelated nuts with cotter pins which I installed.
I also installed the bolts, nuts and cotter pins on the idler assembly. The plans called for the bolts to be installed from the outer side of the assembly but if you do, you will not be able to remove them once the assembly is riveted in place so I installed them from the inner side.
