Brief Description: Began fitting the wing spar attach brackets
Re-clecoed the side skins onto the fuselage so I could start fitting the wing spar attach brackets. Also drilled the new instrument panel attach bracket to the side skins. Cleaned up the NACA vent installation, removed tape and extra proseal around the edges.
