Brief Description: Drill & ream motor mounts for AN3 hardware
Drill & ream motor mounts for AN3 hardware. Also drilled cowl mount hinges and brackets to fuselage frame angles.
I have access to a vinyl cutter and I made a couple steciils for the stainless steel firewalls, top and bottom. I'll apply the stencils and then engine turn the firewalls. The vinyl protects the stainless steel from the engine turning process and when finished, I remove the vinyl and the pattern of the stencil will remain on the FW as clear stainless steel. I'll probably do the engine turning in a couple days.
