Joe's OneX #129 Project
Date:  12-5-2013
Number of Hours:  4.00
Brief Description:  Worked on static system
Mounted two static ports in the fuselage sides and routed the tubes from the ports to the location where my DYNON SkyView AHRS module will be mounted. I used two machined static ports from Cleaveland Tool in Boone, real nice parts and they are 100% compatible with the 1/4" plastic air fittings that are popular for experimental aircraft. The ports require 1/2" holes and are glued into place using Proseal.
Inside fuselage ports held in place while Proseal sets
AHRS platform between the 1st and 2nd bulkhead
Outside view of one static port
