Joe's OneX #129 Project
Date:  11-14-2013
Number of Hours:  4.50
Brief Description:  More tail feather stuff
Made a couple new parts, mounting angles for HS & VS, installed those parts. Installed two rudder stops. Drilled and clecoed 3rd bay pulley assembly for rudder cable so it will not rub on the aileron pushrod. Drilled side access 1/2" hole for the AN4 bolt that attaches the tail spring rod to the fuselage angles.
Will attempt to drill the rear VS spar for the titanium rear spring rod. A friend made a drilling jig for me so I hope it will go smoothly. See my Tools section for pictures of the jig which is pretty neat, hope it works well.
3rd bay rudder pulley assembly
Rudder 1/8
Rudder 1/8" shim stops
Elevator 1/4
Elevator 1/4" shim stop
