Have not been able to work on the OneX much lately but did find time to build some racks for the VS and HS once they are finished. May be overkill but I don't want to see the pieces damaged while sitting around the shop. Besides, someone else may be able to use them when I am finished.
The racks are basically slings made out of cheap carpet attached to 2 by 4 frames. The HS rack has two slings each with the cradle at a 22 degrees angle to accomodate the sweep of the HS. The cradles are deep enough so the rudder and evelators should fit down into the sling also.
