Brief Description: Made flap hinges and started on Aileron hinges
Made flap hinges and started on Aileron hinges; similar process as the elevator and rudder hinges. Should finish the aileron hinges tomorrow, only the aileron side of the hinge will be predrilled. Apparently the wing skin is prepunched for the hinge so the wing side of the hinge will be match drilled to the wing skin using the prepunched skin as a guid.
