Brief Description: Finished cleaning up VS & HS Spars
Finished drilling to 3/32" and cleaning up VS & HS Spars, diffucult cleaning the edges of the cutouts in the spars. Used a dremel tool with medium sanding drum for the inside cutouts. Used standard 6" 3M scotchbrite wheel to cleanup the outside edges. Also used the 6" wheel to cleanup and remove the aluminum splashes on the parts caused by the LASER or Plasma device used to mark the holes. Very sloppy way for Sonex to mark these parts for drilling. Wish they would make the holes in these the same as in their machined angle pieces which have very clean holes and edges.
