Brief Description: Riveting the Horizontal Stabilizer
On the left side I riveted the HS-601PP skin to the HS-702 front spar and the HS-708 rib. Also fay sealed the HS-603PP rear spar and then riveted it to the HS-405, HS-708 and HS-706 ribs. On the right side I riveted the HS-601PP skin to the HS-702 front spar until I hit a bad hole. I'll need an "oops" rivet for that and will order some of those in the morning. I also fay sealed that rear spar and then riveted it to the HS-405, HS-708 and HS-706 ribs.
