Brief Description: Riveting the Horizontal Stabilizer
Riveted right and left HS-702, HS-404, HS-405, HS-708 and HS-706 to the top skin HS-601PP. Then fay sealed the bottom front spar and ribs to the skin. Got a little rivet happy and got ahead of myself but should still be able to peel back some wet skin enough to rivet the HS-405 rib to the rear spar. A bit messy but clean up comes later...
