Brief Description: Riveting the Horizontal Stabilizer
I riveted the HS-706 and HS-707 ribs to the top of the skins, followed by the bottom side. This took clecoing some of the other spars in for support as well as the Missus to help hold the skin down. One rivet got upgraded but the rest turned out well.
I also got a very helpful hint from Mike H. about removing the sealant without removing the primer by using acetone. Thanks again Mike!
