Brief Description: Preparing the Horiz Stab for Assy
Deburred, dimpled and primed the left horizontal stabilizer spars, HS-603PP rear and HS-702 front. Primed the reinforcement angle HS-710 and HS-714. Began wet assembly of rear stabilizer. This included wet assembling the HS-411BPP, HS-412PP and HS-413PP hinge brackets, and the HS-609PP reinforcement bars to the HS-603PP rear spars. Also, the HS-405 main rib and the HS-404 nose rib to the HS-702 front spar.
left horiz stab spars and reinforcement bars primed.
