Jean RV6 Construction Log
RV6
Cowling
9-24-2023
Completing the removable air scoop
Built flange and added nut plate for finalizing the removable air scoop. It sound easy based on that one sentence buy there is more to it.
I final routed the cable for the door trap under the air bowl. attached the rubber piece to the nose of the air bowl test fit, adjust and sealed it.
The only thing left to do is to add fillet material where the cut was made on the air scoop to reduce the visual of it but this is mostly esthetic.
I think I am at the point of gluing (fiberglassing) the air scoop to the bottom cowl.
Note also the round hole above the scoop ; that is where the camera will be inserted to see forward and below the nose when on the ground !
Added fiberglass flange
Fitting the air scoop om flange
RV6 Home
2734
Cowling
1163
Instruments
Other
Propeller
747
