Brief Description: More nut plates - new battery rack, interior
Over all a good 2 days of work ! I kept installing nutplates and found out I need to order some more. But yhe whole top skin will be all screwed in next weekend.
Also elected to choose the EarthX battery 680C instead of the Odissey PC680 so I had to remove the odissey rack, install the EarthX , cut to proper length the 2g + & - wires , added their terminals at the end, primes the rack, etc... with that I am saving 12 lbs ! The EarthX battery weigth only 3 1/4 lbs for the same CCS @ max 680 A. More expensive but I like the lighter rack , the battery hold down system and the great little battery.
Finally started to insulate the far forward inside wall which permitted to install permanently the fuel tank air breather line . This is possible because I am screwing the F-671 skin. That is a major hastle that I won't need to deal with .
Progress is slower than I would like. I was hoping that by now the cowling would have been installed but that is not the case . I will not cut corners so painting will probably be delayed a bit further out.
