Today I continued on installing the empenage fairing , more fiberglass and testing the installation of the rudder. or the rudder it took me some trial and error to adjust the pivot points so the rudder look straight against the vertical stab.
I still need to tap the holes for both under the stab fairing. As for the fiberglass, it will require sanding. Last thing would be to use some heat to try to redress the flanges that are upward twisted.
