Jean RV6 Construction Log
Date:  5-4-2024
Number of Hours:  4.00
Brief Description:  Various
This morning I did 3 things :
Finished wiring the tail ligth . Hard to see but I tried to show the routing I will be using for that. No additional holes drilled and pleanty space for the wire movement.
Then I drill & tap the fairing under the HS. One side for now.
Finally tried to install the tail wheel link I bought at JD Air but as plan calls it could be in length between 12.25" and 13.125" ... it sits as received at 13.125" but I could not figure how to shorten that length. In the installation, it mentionned about the min and max but I could not figure how to do it. So I wrote Darwin @ JD Air to find the answer ... more on this later !
Tail light wire
Tail light wire
Screwed on fairing under the HS
Tail link too long !
