In the last 3 days, I have done so many things, I cannot put pictures of everything. In no particular order, I have prepared the elevator push rod as I am going to install the elevators in position so I can reinstall it fast at the airport.
I have also worked on drilling the vertical Stab and had to add a shim between its forward spar and the union plate that will be attached with the horizontal stab.
Not sure if I mentioned it but the com antennas that I had ordered a few years ago were the wrong one. I needed the Rami AV 17 and purchased the Rami AV-534. So I ordered the new ones and since the base is much bigger, I installed them under the seats so the foot of a person would touch it as you enter or exit the airplane. As you can see on the picture, the clearance from the ground is much better than the AV 534 I originally bought.
