Jean RV6 Construction Log
Date:  4-18-2024
Number of Hours:  8.00
Brief Description:  Checking the empenage
A leap to the past ! I pulled out from a 5 years storage all the empenage parts. I did not finished them completely. I had to foin the leading edge which was a thougher job than I tought. Then I added the counter weight and checked the fiberglass tip. Some were missing nut plates and all of them need to close the end that is open. That will be for tomorrow.
showing the elavator leading edge
Rudder & both elavators
Fiberglass not even drilled !
