Jean RV6 Construction Log
Date:  4-16-2024
Number of Hours:  11.00
Brief Description:  Doing the SB00036
Yesterday , I mainly worked at fixing my headset plug connection error. I did not work the whole day but long enough to fix it. I still have one last issue which is a background noise when the Nav2000 is on. I am unsure how to fix this although I double checked my connections and grounds and everything was done correctly.
Today, I wanted to change the pace and decided to bite the bullet and start doing the SB00036 on the Horizontal stab, for the 2 outboard hinges that required a doubler to be added. It is quite a long thing to do because of the required caution with all those rivets removal. Also to reposition the hinge at exactly the same place is not as simple as it looks. So 50% of it is done, the other half will be done by tomorrow.
never flown hinge !
never flown hinge !
Outside doubler
Outside doubler
One done !
One done !
