No pictures from yesterday or today's work. Essentially I worked on installing the flap mechanism and wasted 3-4 hours trying to install the Ray Allen positionner to no success.
I had to change the actuator polarity in the VPX because the motions were reversed. Easy task with the VPX.
I also managed to finish installing all the remaining nutplates for the luggage area.
Tomorrow I would like to install the micro switch that will say if the canopy is latched or not. Priming the side panels of the luggage area , attaching the loose wire , sliding in place the push rod between the front and the center of the airplane ... sounds like a plan.
