Jean RV6 Construction Log
Date:  3-26-2024
Number of Hours:  12.00
Brief Description:  Connecting the stick , installing the RG400 for th
In the last few days I am doing cleaning, making sure everything is tip top, doing some connections that were not yet connected.
I prepared the 2 RG400 coax cable for the 2 antennas ... one is directly on the radio and the second is for the backup radio that is a hand held one , hence why you see a panel mount BNC connector beside the fuel valve.
I also connected the stick and to insure they would be removable , I am using OLC-2 connector that are using set screws to secure the wires.
Clean area under the co-pilot side.
Ready for the antenna
See the BNC panel mount ?
