Jean RV6 Construction Log
Date:  3-20-2024
Number of Hours:  3.00
Brief Description:  Cockpit work
Today I had to re-do 2 fuel pipes to make a much cleaner area under the fuel selector. I installed at this lowest point the flyboy gascolator and to do the piping was a frustrating work ! You can see the numerous attempts in doing this task. The tube bender is quite hard to use properly and it took me several attempts and material to finally make it right . Tomorrow I will be moving between the seats.
Attempts collected !!
Fuel pump all connected with the gascolator and the valve selector.
The other side
The other side
