Jean RV6 Construction Log
Date:  3-15-2024
Number of Hours:  6.00
Brief Description:  Riveting nutplates on bulkheads
Not sure how I spent all those hours but I did ... I riveted the nutplates for one thing along with the gap filler plate behind the prop.
Then, I cleaned out the inside of the cabin as I plan to completely finish the inside as I bought the carpet yesterday. The carpet was bought at Manx Manufacturing and it is a wool carpet fire rated for aircraft. It seems to be very light , looks good and I am quite keen to see it installed.
If you wonder why I am not completing the cowling first, is that I am tired working on that so I think a switch of things to do will / should be beneficial.
Not plates on the fwd bulkhead
Nuitplates on the rear bulkhead
Cabin cleaned out ... time to put it together.
