Jean RV6 Construction Log
Date:  11-20-2023
Number of Hours:  3.00
Brief Description:  Baffle
These days I've been so busy that I have not worked much . Yesterday I did 3 hours and worked at adjusting the baffle for the perfect fit. I still have parts to install and trim before cutting the contour before the rubber seal fitting step.
One thing I did also was to sand the back end of the bottom cowling because to insert the hinge pin was a real battle. Now it is much better but does slide in as easily as I would like it to be.
the fit against the cylinder is good now
