Brief Description: Accessories linked to the cowling
Smaller weekend than expected but I am progressing.
Manage to complete the oil stick access panel. I also installed the alternate air trap for the induction in case there wiuld be a blocage in the air air scoop. A mandatory requirement to fly IFR.
I also modifiied the air filter casing as required. The scoop is higher so I had to cut the side to tilt it appropiately. I also had to do some reinforcing fiberglass where I had cut in. I also installed the recess on the pilot side because I have an injection system which the arm movement of the mixture would have interfere with the air filter bowl.
