Jean RV6 Construction Log
Date:  7-30-2023
Number of Hours:  12.00
Brief Description:  Accessories linked to the cowling
Smaller weekend than expected but I am progressing.
Manage to complete the oil stick access panel. I also installed the alternate air trap for the induction in case there wiuld be a blocage in the air air scoop. A mandatory requirement to fly IFR.
I also modifiied the air filter casing as required. The scoop is higher so I had to cut the side to tilt it appropiately. I also had to do some reinforcing fiberglass where I had cut in. I also installed the recess on the pilot side because I have an injection system which the arm movement of the mixture would have interfere with the air filter bowl.
Oil stick door
Oil stick door
Alt. induction under the air bowl
Fwd filter bowl mod.
