Jean RV6 Construction Log
Date: 3-5-2023
Number of Hours: 16.00
Brief Description: Red cube install, small errands and garage
Most weekend was spend on reorganising my garage while planning the painting for next June. I think I figured it out as I used my previous painting project to have a better setup.
Couple weeks back I received the fuel hoses I ordered and then this weekend I installed the red cube fuel flow sensor as per their instructions. Straight line feeding , supported only by the hoses, not attached to the engine, no angle in or out of the cube, wire facing up, installed after the mechanical pump on the engine and away from the engine heat ! That is a ton of restrictions. In fact, I do not recall seeing a red cube installation that met all the criterias stated on the instructions from the manufacturer. Therfore, to meet all conditions along with the RV6 engine bay space restriction, it is probably the most complicated sensor to install by far.
Finally, I have received my propeller ... finally ! Quite happy with it and look forward to install it !
Red cube hanging by the hoses
Thighter hose radius than I wanted , but that is the best I could do
View from the fuel servo
