Jean RV6 Construction Log
Date:  1-28-2023
Number of Hours:  3.00
Brief Description:  Flag terminals & brackets
Today I got my new flag terminal crimper and proceeded to connect the ground wires that I routed there. The flag terminal are nice as a wire routing preference but there are using a lot of spaces. The reason for these terminals is to let the batttery in and out easily. You can see on the picture the cardboard that represent the battery sitting on top of it's rack.
Next the bracket is completed as I added a second piece to secure that mixture cable. That appears to be perfect. I hope that I did not forget something that will force me to rethink that because it was not as simple as I wanted.
Flag terminals on the ground block
Brackets added to route the mixture cable
Mixture cable attached
