I kept doing some final wiring of a few items thinking of the ability to remove them for changing them should this happen. As an example I used a molex connector on the redcube.
I also added a bracket for the mixture cable and measured / ordered the -6 hoses for the fuel feed , one from the mechanical pump to the red cube and the other from the red cube to the fuel servo. Expensive hoses but I went for the safest one in my opinion, which is the integral firesafe hose style. Pictures on the hoses will come later when they will be installed.
