Jean RV6 Construction Log
Date: 1-14-2023
Number of Hours: 6.00
Brief Description: Small stuff but takes up a lot of time !
Still waiting for my propeller , so I am installing other items .... Among them, I decided to add an oil separator but I had a hard time to fugure where to install it. The oil that will be collected will be returning to the crank case but I was unable to screw the fitting in because of the engine mount. So for now I left this aside .
On the oil separator, please note that I insulated the hose from the breather because after reading a really good article on kitplane, which was dated of 2014, it explain well the importance to get the fumes as hot as possible so the water will not condense and return to the engine casing, but will be evacuated.
I installed the MAP sensor on the top right of the firewall. I still need to do the connections but at least the sensor is installed.
I also installed the fire extinguisher. Like everything that I installed, it needed a doubler, primer, rivets ... I had seen an other builder who had installed his extinguisher at that location and I felt it was a good location, easy to access .
ASA oil separator
Dynon MAP sensor ... (same as for cars)
Extinguisher
