Jean RV6 Construction Log
Date:  11-27-2022
Number of Hours:  11.00
Brief Description:  Gear leg, brake & Wheels
Desappointing as I thought the wheels would be installed by the end of the weekend. But I encountered many issues. Although I am very close to have the wheels on the gear legs, it took me a long preparation time.
The gear legs needed to be primed to get a corrosion protection and greased where metal was left unprotected. Then I did not realise it but the shaft for the wheel was actually a little bit bigger which prevented the bearings to go over it. I sanded it down and it worked but that delayed things.
Also, I am using an older wheel kit and the wheel pant support was not super easy to install and in fact it requires more adjustment because it touch the braking disc.
I will finish it this week during evenings because I want to install the engine next weekend.
The leg is all greased out inside the engine mount tubing.
Drilling the brake flange on the gearleg
Shaft sanded down .
Shaft sanded down .
