Jean RV6 Construction Log
Date:  3-20-2022
Number of Hours:  7.00
Brief Description:  Various wirings & new knob installed
This weekend, although I did not put much hours, I managed to add a forgotten necessary knob for the oil cooler; I will need to add the writings about that knob usage ! I also installed the dual AHDARS and fixed a few connections. As you can see, my ground block is getting filled in !
You can see the dual ADAHRS network connectors going into a single one which is hanging for now. Even the connecting white static air intake tubings are not secured yet... I really find figuring to decide where the wires will be running along is an art in itself. Way more complex that I thought.
Oil cooler knob added
Ground blok getting more connections
ADAHRS 1 & 2 bolted
ADAHRS 1 & 2 bolted
