Jean RV6 Construction Log
Date:  3-6-2022
Number of Hours:  12.00
Brief Description:  Wiring continue
There is not much to say about wiring. It is about following a plan , follow the plan step by step, and double check everything. What I could say about wiring other than my previous sentence would be it's very difficult to plan the wiring routing because there are a lot of unknown. As you can see in my first picture, I took the big dive, meaning I installed the PPS (Primary power supply) and hopefully it is at a correct location. I've made a lot of research but I could not establish any location that seems to be suitable. So I took a deep breath and got a place that seems to be logical. I just hope I am right.
One thing I learned this weekend was to install BNC & TNC connectors on a coax RG400 cable. It took me a few attempt to make my connection perfect. Although there are many tutorials videos that makes everything looks so simple, there is nothing that equals a try that you do yourself ! So I did 2 cables for the ADSB & XPDR !
I'm moving in the right direction !
PPS on the firewall !
A view of the wiring from inside .
BNC on RG400 for the ADSB here
