Jean RV6 Construction Log
Date:  12-29-2021
Number of Hours:  8.00
Brief Description:  Canopy, metal preparation
Metal preparation once the initial #40 holes were drilled, was to, after removing the canopy, essentially enlarging the holes to a #6 diameter. That includes all the standard preparation, meaning , deburring , cleaning , dimpling when required. The only hole I decided to countersink rather than dimpling was the one in the middle of the aft structure attaching the roll bar. I also made a 1/2 hole in that 4" structure bar to give an access for the nut that will attach the screw.
The exception to through holes were in the roll bar where I drilled and tap all the holes to accept a #6 screw.
Countersink hole due to it's location
Tap hole with test screw in the hole.
dimpled C630 side canopy skin
