Brief Description: Adding components & preparing for final riveting
I did not have the chance in working much this past weekend . Only Sunday and I was sick as a dog so I worked at a bery slow pace.
I finished drilling in some of the equipment support/brackets. I had an issue with my bellcrank bolt that somehow was not aligned perfectly . To correct that, I added 23 small 1/16", 2024T3, pieces that squishes the little wall and angle and re-drilled the whole thing . It was time consuming to get it perfect and strong !
I also cleaned up all the dust & chips as I will re-spray touch up of the grey primer. My plan is to add everything that needs to be added that will ease the instalkl as it is all opened up now.
Next weekend, I think I have a full weekend and plan to debur , dimple, prepare start some riveting, add some cable. Lots to do but it does really starts to become the dream that will come true !
Pitch servo bracket, ELT support
ADAHRS support--under the rear platform that has been parked there temporarily
