Jean RV6 Construction Log
Date:  5-23-2021
Number of Hours:  5.00
Brief Description:  Center console
Today I worked and completed most of the trimmings of the center console and re-did a few fuel lines that were almost conflicting or that were not to my liking. One of those was the line between the gascolator and the filter and also from the pump to the firewall. The later was reworked because I did not want that fuel line to be in contact with the floor and will be adding insulation under to prevent heat transfer from the floor to the fuel line .
The connection of that line with the firewall with the tightes radium I can make protrudes the fuel line past the cover . Because of it's location I will make a strong protective cover to protect it from possible feet kicking, although it is past the rudder pedals.
