Brief Description: Electric flaps system & manual aileron trim
It definitely goes slower. Installing equipment takes much more time than I anticipated.
But overall I've made progress and I am please with it. Essentially the electric flaps system is ready and could be install when needed. Because of the floor angle, I elected to modify the front end side panels by cutting them to permit to follow the floor. As you can see, I added a small doubler to hold the floor shape. That will not be seen as the seat will be thicker than the double you see on this picture.
The aileron trim was a little challenging because I had drilled the holes for the floor but it was interferring with the plate holding the device.
