Jean RV6 Construction Log
RV6
Structure assembly finishing
Finished assembling the structure. I also position & drilled the locking bolt hole for the tail wheel rod assembly. Next step is to clean, debur, prime, dimple ... to put skin on after ....
Using a 0,030" spacer under F627
F611 bulkhead showing angle added
F610 bulkhead showing angle added
RV6 Home
2729
Cowling
129
1163
Instruments
Other
Propeller
747
