Brief Description: Installing fiberglass tip on HS
I have decided to use #6 screws to secure the fiberglass tip instead of using pop rivets. I still need to close off the ends but I need to have the elevators attached to adjust the gap correctly.
My HS is now complete until I can finish it up after inspection that should happen in, hopefully before next spring !
