Jan Hanekoms RV Web Site
Date:  12-17-2010
Number of Hours:  10.50
Brief Description:  Final assembly
Final assembly.
Install luggage compartement bulkheads.
Install front lap safety harnesses.
Put on wing walks.
Finish trimmer wiring.
Found fuel leak at fitting on RG side. Remove pipe with fitting and redo.
Finish and install top and bottom wing root fairings.
Install marker beacon and DME antennas.
Install cowls.
MAIDEN FLIGHT.
Snags found.
Pitot pipes swopped - corrected.
LH tank flaot sensor sticky.
