Install RH wingtip. Install compass. Install fire extinguiser. Fill fuel tanks and calibrate dynon. LH tank has a problem - does not want to calibrate. Do inspection for provin flight with AP. Do first engine run and fix oil leak on oil presuure sender pipe. After that two more runs to test and set up dynon properly. Fix problem with fuel selector not in right position.
