Terry's Sportcopter Vortex
Date:  7-27-2019
Number of Hours:  1.75
Manual Reference:  Pge 107
Brief Description:  Control Rods and Bell Cranks
This is a departure from the original design by Sportcopter. One of the enhancements they did was to add the bell cranks to the lower mast to reduce control rod vibration and thereby reducing the vibration at the stick. As you can see in the pictures below, they are securely mounted to the lower mast, and will provide an excellent range of motrion for the control rods.
Bell Crank Assembly parts
Bell Cranks attached.
