Brief Description: Antenna Mounts and Heading Sensor Mount Spacers
This is a culmination of 8 total hours of work. With the Digital Heading indicator I will be using on my Gyro, i need to find a place to mount the sensors, which will end up on the keel. Where they need to go would interfere with the rudder cables, so I designed and had fabricated 2 spacers to raise the enclosure up to clear the cables. I also designed and had fabricated the antenna mounts for the radio and transponder. They are all getting painted now. Once i receive them back, they will be mounted!
