Brief Description: Cleaning up of Fabricated Parts
I received my parts from being fabricated from the plans I designed. While I was at it, I designed some parts to hold my pull start handle from my Rotax Engine. The original design was to pull the start from the seated position. Since I have a bad right shoulder, I decided that I would pull the start (if needed) from the right side of the gyro, and as such the handle would interfere with the push rods. So, I've designed a "hook" to store the handle when not in use which keeps it out of the way when in flight.Took my parts and cleaned out all the mounting holes.
