Today was another mixed bag of work. I gathered the items I needed to work on the rudder, but put that off another day as I needed 2 bolts but found I was shy 1. Off to Aircraft Spruce! In the meantime, I mounted the ground cable to ground the gyro frame to the battery. Once I returned from Aircraft Spruce, it was a bit too hot in the garage to finish up the rudder. That will happen tomorrow.
