Brief Description: Pneumatics, Electricial and Avionics
This was a mix of items worked on today. I was able to mount the Starter solenoid, the voltage regulator for power. I also mounted the pneumatic cylinders for the air trim system on the Gyro. And finally, I mounted the box which will hold the components for the compass and HSI info to the keel.
