Today I also finished securing the controls for the joy stick. The controls were initially fitted, but required a set screw to keep it from moving or lifting up. A stainless steel screw was fitted under the foam grip after the hole was drilled and a stainless steel screw was used to cut the threads in the aluminum stick.
