Brief Description: Throttle and Pre-rotator Quadrant
More small assembly work to do. This will be the throttle and pre-rotator controls on the quadrant mounted on the left side of the pilot seat. the smaller control is for the pre-rotator and it has a nifty latch so when the pre-rotator is engaged, you don't have to hold it in place while the engine is spinning up the blades. Whern the blades are at speed, you release the latch and the lever drop back down. The large hole had to be drilled for the starter switch - it was drilled on the quadrant cover, but not on this part.
