I finished securing and cut the servo harnesses to length. The left servo harness also had to be routed through some sections with grommets. I did the pinout and secured the cables to the floor with stick on cable tie mounts so the cables wont flop around. I mounted the CWS switch on the panel above the throttle quadrant. I FINALLY finished securing cables and bundles behind the panel. Now the seat pan is back in and the cabin is cleaned up. I made a fused cabled to hook up the battery tender and secured it to the motor mount. It will stay attached to the terminal and the charger can hook up in the cowling cutout for the right gear leg.
